Shop setup
Started by Stovepipe, June 16, 2022, 01:42:59 AM
Stovepipe
I've been reading all I can and finally completed my setup with help of my close friend. I just sharpen as a hobby and something to do in my retirement. Though some would be interested in my setup.
Welcome to the forum, Stovepipe. Nice set up!
RichColvin
Quote from: Stovepipe on June 16, 2022, 01:42:59 AM
That is ENTIRELY TOO CLEAN!
Rich Colvin
BeSharp
Very nice setup! I'm impressed!
Is the riser for the right side T8 water trough 3D printed? (I use two stacks of two hockey pucks each).
3D Anvil
Stovepipe
Quote from: BeSharp on June 16, 2022, 04:37:57 AM
Its the regular T8 water trough. I just put a couple rubber blocks under the wheel. Problem I'm having with it is the water from the knife drops on the drive wheel and doesn't turn. I made a "Rube Goldberg" AL cover when sharpening that solves the issue, just looks like hell.
Stovepipe
Quote from: Ken S on June 16, 2022, 03:00:54 AM
Thanks Ken, appreciate your opinion.
tgbto
Quote from: RichColvin on June 16, 2022, 04:02:22 AM
Right, I initially thought I could use that as an argument along the "look darling, some hobbyists have much more stuff than I do", but she'd immediatly point out how professional and clean this all looks.
Great job !!!
van
Congratulations on your work station. Order and cleanliness first of all.
How did you make the cover to protect the drive wheel from splashing water? Interested in a solution.
Kindly yours
John_B
What other hobbies do you enjoy using this shop?
Sharpen the knife blade
Hone edge until perfection
Cut with joy and ease
Stovepipe
Quote from: van on June 17, 2022, 12:45:19 PM
I just folded some aluminum foil and had the water run into the lower pan. I'll get a picture of it, however, kind of embarrassed. I'll comeup with a permanent solution in the next few days.
cbwx34
#11
Quote from: Stovepipe on June 18, 2022, 10:26:23 PM
There are "Drip Trays" being made (or you can print your own if you have a 3D printer).
Edit:  Here's some more links...
https://www.thingiverse.com/thing:4791736
https://www.printables.com/model/188557-tormek-drip-tray-for-fvb
https://www.youtube.com/watch?v=A97KhtUZfFc
Stovepipe
Quote from: john.jcb on June 17, 2022, 06:48:49 PM
Making parts for offshore fishing boat "StovePipe" and keeping filet knives sharp for boat and others who share the dock.
Stovepipe
Quote from: cbwx34 on June 18, 2022, 10:33:12 PM
That's awesome, thank you very much!!!!!
3D Anvil
Or if you don't have a 3D printer or a friend who has one:
https://schleifjunkies.de/produkt/abtropfschale-fuer-t8-in-verbindung-mit-vertikaler-frontbase/
Unfortunately the shipping from Germany isn't cheap.
