Repainting my new-to-me 2000
Started by Inspector212, May 24, 2022, 09:17:28 PM
Inspector212
I picked up a Supergrind 2000 at an online auction for a good price. I got it home to discover the stone was cracked and the shaft was seized and the frame was covered in rust. I decided to rebuild it. I bought the SS shaft. I have yet to decide on what wheel to buy. I'm thinking CBN. I am going clean up and repaint the chassis. My question to the group is, what color? I could go with something close to the original green but was thinking why not change it up. I like the Rustoleum Hammered line of colors. I was thinking bronze. What do you think?
Inspector
https://www.rustoleum.com/product-catalog/consumer-brands/stops-rust/hammered-spray
As a first wheel, I would follow the traditional Tormek advice and start with the SG-250. With CBN or diamond, each wheel is limited to one grit and the grit is only one layer deep.
RickKrung
#2
Quote from: Ken S on May 24, 2022, 10:11:25 PM
I have to agree.  If I had to have just one wheel, it would be the SG.  There is a lot of learning to be had there, very important before you can really make use of the specialty wheels like diamond or CBN.  To use the diamond and/or CBN wheels, you have to have a couple or several.  That makes an SG as a starter a heck of a lot cheaper if you find this system not to your liking.
Rick
cbwx34
Quote from: Inspector212 on May 24, 2022, 09:17:28 PM
Inspector
You should paint it gold.   :D   Bronze looks good though.
Add me to the "get the stock wheel" camp... if you go CBN, you'll probably need more than one.
Post pics when you're done!
Inspector212
Do I need the truing tool if I buy the stone wheel?
cbwx34
Quote from: Inspector212 on May 25, 2022, 04:25:21 PM
Yes  :)
RickKrung
Quote from: cbwx34 on May 25, 2022, 04:57:14 PM
Yes  :)
And a stone grader.  But...  Please do not be daunted by what will seem high initial costs.  There truly is a lot of learning to be had using these before you can really make good use of the others.
Rick
3D Anvil
I was recently in your position as a newbie seeking advice on a first wheel ... and got the same advice, which I took.  I've since added a CBN 160 stone which I'm using on the drive wheel side.
The advice to start with the SG stone was solid, and here's (one reason) why: if you're sharpening knives, it takes some practice to keep the bevel flat on the stone ... particularly when setting the blade to the stone initially.  If you come down at an angle, or tilt the blade once it's on the stone, you will hit the edge of the stone and create, at minimum, a mark on the bevel.  At maximum, you'll take a divot out of the bevel which takes some time to repair.
Because CBN and diamond stones cut much faster than the SG, any mistakes you make will be compounded.
Good luck, whichever way you go.  It's a great system.
Inspector212
I looked in the pile of fixtures I got with the Tormek. I got the SP650 stone grader, SVS-50 Multi-jig, SVH-320 planer blade jig, a couple of knife jigs, wood turner's kit, hand tool kit, and an older style truing jig, cannot find the number. So, I already have the truing jig. I will buy the original wheel and get learning. Thank you for the help.
cbwx34
A forum thread (with links to other threads) you might find of interest...
Refurbishing Thread
Rimu
Cool... I vote for the color: chrome
