T4 or T7?
Started by Ken S, October 31, 2014, 02:27:19 AM
Choosing between a T3 (now T4) and a T7 is a frequent post on this forum. Almost all of us are T7 users.  Invariably the advice has been to favor the T7. My advice has always been that the smaller units may be desirable in small work areas or in situations requiring light weight for portability or for older users.  I have never felt the price difference was enough to be a major consideration.
I had the opportunity to examine the T4 this afternoon and discuss it with two Tormek experts. I still believe the price difference between the T4 and T7 is not enough to be a serious consideration, especially for those of us who sharpen woodworking tools. (The T4 does not come with the SE-76 square edge jig.  The T7 does come with it.)
Getting beyond the cost difference, I was surprisingly pleased with the T4. The cast zinc top with machined sleeves for the universal support bar is much more precise than the old plastic. The entire unit had a more solid feel. It also has a sturdy handle. The supposedly "fifty per cent duty" motor is most unlikely to burn out with home or light commercial use. I would not factor it in.
Over the past years, I have purchased two T7s.  (The first one was stolen.) When I needed to replace the first unit, I automatically chose another T7. If I needed to purchase a Tormek now, I would probably choose the T7 again.  However, that decision would be heavily influenced by the fact that I already own the black and Japanese wheels.
If I did not already own the two extra wheels, the decision would be difficult. It would come down to the smaller size and weight of the T4 or the ten inch diameter wheel of the T7. Considering most dry grinders have six inch wheels, with eight inch being a smaller number of more deluxe models, I think the eight inch wheels of the T4 would more than suffice for my work. My Tormek does not leave my shop. The shop is large enough that Tormek size is really not a consideration. If I traveled with the Tormek or had a mobile sharpening service, I would definitely opt for the smaller unit.
For those of you who are debating which model Tormek to purchase, I urge you to consider the choice carefully,
jeffs55
I made up a saying for which I am quite proud. It goes like this, "you can use less of more but you cannot make more of less". It means that you can use part of a larger or more powerful thing, but you probably cannot make a smaller or less powerful thing big enough or powerful enough. Go with bigger, in this case the T7. When was the last time you regretted buying the best?
SharpenADullWitt
No different then the "value" argument, it is a personal thing.  I use mine for lots of things, but the friend whose restaurant has sent me knives to sharpen, well that is all they would use it for and if they had something like the T4 to hone or touch them up often, that would be all they needed.
8)
I can see both points of view.  In the past, I have always leaned toward over buying. However, years later, I have realized that I did not need as much excess capacity as I dreamed I might. For anyone who routinely sharpens several hours each week, I would lean toward the T7, especially if doing heavy work. For the home woodworker who keeps his plane blades and chisels in top working order, with some kitchen knives, the T4 should be more than adequate.  Even with something like turning, a turner using a mini lathe to make pens would need well sharpened tools, but the sharpening setup need not be heavy duty industrial.
The decision should be based on the reasonably expected work load.  I do not see the T4 as having lower quality.  It is just designed for a lighter work load.
Herman Trivilino
Quote from: Ken S on October 31, 2014, 07:25:05 PM
That's a difficult thing to judge. If we under-buy we notice it when the tool is not up to the task. If we over-buy we are less likely to run into a situation where the tool is not up tho the task, but we are also less likely to remember it happening. We tend to recall failure more often than success. It's part of being human.
Origin: Big Bang
#5
Regarding the cost differnce between the T4 and the T7:
The November Rockler brochure shows the T7 with free rotational base and knife jig for $665, the standard price.  If that includes free shipping, that puts the T7 and the T4 on almost equal footing. The brochure states free shipping with some exclusions. That puts the decision back to weight and bulk versus the larger diameter wheel.
Ideally, I would see if your local Tormek dealer would match this.
jeffs55
I think a lot of consideration should be put into what the future might hold. If a T4 is presently adequate for your needs, will it be next year? Are you going to be stuck even if by your own choice in "today".  Like I said, you can use more of less but you cannot make more of less. Consider a gun safe that is presently adequate for your needs but just barely. Will even one more firearm render it inadequate? You can probably squeeze in one more but what about two more? At some point you have run out or room and will not be able to protect something or in this case, be able to use your tool for more than 30 minutes without a cool down. Do you want to go watch TV every half hour or so and then come back to what you were doing? If cost is a factor and you saved up for the T4, then save some more and get the T7. You could never sell either for what you paid for them and first loss is least loss.
grepper
I'm a little in both camps, but mostly with jeffs55.
I HATE wishing later that I should have purchased something better, especially when it's durable goods such as a Tormek.  I've done that often enough.  I like to be happy and love and appreciate my tools every time I use them, rather than the repeated depressing feeling of, yea it will do, but it's kind of a piece of crap.  Or worse yet, having to replace it later with what I should have purchased the first time because it really didn't work out because it was wimpy or underpowered, or breaks and turns to a pile of junk as seems to be happening more often now as just about everything is specially imported from the Orient and was junk to begin with.
Onion other hand, I would not buy a bulldozer to plow my driveway.
I believe we must keep two things in mind with this discussion:
1) None of us has actual experience with the T4. (to the best of my knowledge, please feel free to correct me if I'm wrong) We are comparing a known product with an unknown product.
2) The T4 is not a cheap knockoff.  It is manufactured by Tormek, just like the T7.  With the exception of the support bar and water trough, it uses the same jigs and accessories as the T7. It includes a seven year guarantee.  The T7 is guaranteed for seven plus three years. Compare either to a new automobile.
The motor of the T4 is 120 watts vs 200 for the T7. It is not rated for continuous duty. The motor seems to be the same as used on the T3.  I would be curious to hear from Sweden as to how many burned out motors were replaced on T3 units.  I suspect not many. I doubt I would ever exceed the capability of the T4 motor. At my sharpening needs and age, I doubt I would ever exceed the limitations of the T4.
Last week, the two Tormek reps I spoke with pointed out the composition of the drive wheel on the T4.  It is a new Tormek developed rubbery surface which gives much improved traction for the power train. The support bar sleeves are machined directly from the zinc casting.  The machined casting is all one part. I had the impression that the machined zinc casting easily matched and possibly surpassed the precision of the T7.
Examining the T4 briefly, it seemed like a solid, well built unit.  I believe certain situations make choosing the heavier duty T7 a logical choice.  If, like Kenny K in Scotland, I had the responsibility of maintaining two hundred chisels and many plane blades, at least one T7 would be the best choice. For an active turning or cabinet shop, the T7 would seem the right choice, just as it would in a busy knife making or sharpening shop.
I can appreciate the wisdom of planning ahead.  For younger persons with big dreams, I would say go for the gold.  For those of us, who, like me, are retired or contemplating retirement, our future requirements may differ.  For me, choosing the Tormek was largely based on lessening the stress on my hands from using bench stones. My Tormek has certainly accomplished that for me.  When I purchased the first unit in 2008, the T7 was the only choice.  It has served me well.  In hindsight, if the T4 had been available at the time, I believe it would have been very sufficient for my needs.
So, in addition to weighing compactness vs a larger diameter wheel, I would factor in age and realistic future expectations. The decision is personal.  Worst case scenario: if one should happen to choose the wring Tormek, they hold their value well.  Switching would not be costly if the requirements changed.
jeffs55
Something else I just thought of, with the T4 your wheel is 200mm in diameter, the T7 is 250mm. That is a huge deficit right from the start. No matter how little you use the T4, you are starting with a wheel that is 50mm less in size. There are about 52mm in an inch. Will anyone argue that two inches is not significant? In linear measurement it is just two inches but we are talking cubic inches not linear feet due to the pi x r squared x mm thing. There is a lot of mass in that two inches/ 50mm.
grepper
I'm sure the T4 is a fine, quality machine.  It is, after all, a Tormek.
Retail pricing seems to be about $200.00 US difference between the T4 and the T7.  The T4 has no truing tool, which you will need eventually.  That's about $65.00 US + shipping.  It also does not include any jigs.  Seems like one or two jigs might be handy.  I wouldn't want to have to worry about the 30 minute duty cycle either.   If size and weight, or a small amount of immediate cash flow  is not a primary concern, it would be an easy choice for me.
I think Ken S summed it up when he said at the start of this thread, "My advice has always been that the smaller units may be desirable in small work areas or in situations requiring light weight for portability or for older users.  I have never felt the price difference was enough to be a major consideration."
Herman Trivilino
Quote from: jeffs55 on November 05, 2014, 03:26:19 PM
(250/200)2 = 1.5625. You therefore get more than 1.5 times as much grindstone with the T-7 compared to the T-4.
Origin: Big Bang
jeffs55
#12
I could not figure out how to quote and reply at the same time so please read my acknowledgements on the following items.
I recently watch two Tormek T4 videos. The one video was questionable, but includes two interesting statistics.  According to the video, the motor of the T4 is rated for 10,000 hours and the T7 motor is rated for 25,000 hours.
This struck me as odd, so I send am email to support.tormek.se for verification. To my surprise, Stig replied (promptly) that the motor hour ratings were correct.
The above was quoted from a Ken S submission.
This is a reply to my own submission, the reply is from Herman.
It cannot be any clearer. You get 2 1/2 times the motor life and 1 1/2 times more grinding stone upon purchase of the T7. The difference in price does not rate the T4 as a good buy. I know that the cost of the body is likely the same, that is the motor housing within a few cents. It seems to me that the unit cost would have to be at least half the cost of the T7 for consideration. I mean half, not two thirds. While either should last the life time of the casual use buyer and even beyond; the T4s cost is not in line with its designed planned obsolescence.
elliowb
This thread is right on the money.  It has summed up my recent experience with the Tormek system.  I used to do woodworking for a living, but that was years ago.  I still have some beautiful chisels and planes, that haven't been as sharp as they should be for many years.  This past Saturday, after an old colleague noticed the terrible condition of my tools, I was embarrassed and decided to look for a better way to restore and sharpen my tools.
At first I purchased the T4, thinking that as a non-professional, I would never need the heavier duty T7.  However, it wasn't until I got it home that I realized that the T4 doesn't come with any jigs whatsoever (the sales guy at my local Woodcraft store didn't know that either, because he told me it did have the square edge jig).  Without question, I knew I needed the square edge jig for the chisels and plane blades, and I suspected that I'd need the truing and dressing jig at some point to keep the wheel square and flat.  Together, those added up to half the difference in price between the T4 and T7.  That only left about a difference of $130.  Further, when I turned on the T4 (never sharpened anything on it though), it seemed alright, but not well balanced (maybe that was just the copy that I had).  Then I started to rationalize that the wheel on the T7 was significantly bigger (and that would also leave a slightly less hollow grind, making the edge a bit stronger), had a better, stronger motor, and also had the longer catch tray (I have a DeWalt 12" planer, and figured that I could sharpen those blades in the future, as well as long kitchen knives) as well as a longer guarantee.
I strongly recommend that anyone that is considering the T4, more than likely, unless money is a huge issue, you should go with the T7.  The T7 is definitely the value model.
I can't imagine that Tormek will have very good sales numbers on the T4.
Stickan
Hi,
This discussion is good to follow.
The machines are different for different needs, don“t let us forget that. If you are only into knifes, lets say you are a chef or a hunter, the T-4 with a knife jig is a very good buy. It will last for decades. I do know processional woodturners who has the T-4 and love it so it works for them too.
Also, many buy the T-3/T-4 for the size. Its easier to carry around when needed.
If you are into woodturning or in a business like carpentry, furniture-builder and so on (professional) , the T-7 is the machine that will meet all the demands.
Stickan
