Ionut's Small Knife Jig
Started by Herman Trivilino, March 10, 2013, 09:13:50 PM
grepper
Regardless of all that verbiage and complication, Herman's simple tool rest is quick and easy to use tool to have in the arsenal that extends the usefulness of the machine to a wider array of sharpening applications.  A machete is a good example.
Mark, verbiage and complication make the world go round. ;D
On a more useful note, I think someone making one of Herman's HK-50s (or HK-40s) would be wise to make a jig for drilling the holes accurately into the platform. I believe Herman's jig has many uses beyond small knives (and machetes). By using a hole jig, future platforms could easily be interchanged with the original, the raised secondary platform for short chisels being an example. I can envision someone having half a dozen interchangeable platforms for the scissors jig platform.
stevebot
Two other things that are somewhat obvious:
3: the tongue must be long enough to permit low angles, preferably 10 or 12 degrees
4: the knob must be on the right side to be accessibility.
Home improvement stores carry 2" x 1/4" Al stock that makes a nice tongue.
Steve Bottorff; author, teacher and consultant on knife and scissor sharpening.
Herman Trivilino
Quote from: Ken S on June 09, 2015, 05:23:27 PM
The scissors jig base makes a perfectly good jig for drilling holes in newly made platforms. Just use the threaded holes in the scissors base to guide a much smaller drill bit into the new platform, making pilot holes. Then you can widen the pilot holes to the desired diameter.
"Knowledge isn't free, you have to pay attention." R.P. Feynman
Herman Trivilino
Quote from: grepper on June 09, 2015, 04:48:30 PM
I agree, Mark. I use mine to sharpen a variety of items, but my favorite is still the knives I use every day. Pocket knives and kitchen knives. It's just so much easier to set the edge angle and go. If I have several knives to sharpen, all at the same edge angle, I don't have to adjust the jig in between knives.
This is a topic which needs to be kept readily available. The small platform is a very useful, versatile tool. I think every serious Tormek sharpener, especially knife sharpeners, should make one. I have never understood why Tormek does not make one.
cbwx34
Quote from: Ken S on September 04, 2020, 05:32:32 PM
Pin it to the top! ;)
ABall
If anyone is looking for reasonably priced Aluminium flat bar I have just purchased 2" wide by 1" thick and 200mm long from ebay for £13.40 with free delivery, they dont seem to do free for everywhere and the auction suggests they only deliver to local addresses but I just messaged them, (its 23.40) and they got back to me straight away saying my postcode is free delivery and Im in Reading. Ok this is one for UK members only. https://www.ebay.co.uk/itm/201367237820
Alan,
For the "diving board" part of the small platform, 1/8" is plenty thick. I suggest mounting the diving board on the scissors jig platform. As shown in this video, the scissors jig platform has Tormek's patented Torlock, which holds the platform much more securely.
https://advanced-machinery.myshopify.com/products/svx-150-scissors-jig
ABall
Quote from: Ken S on September 16, 2020, 02:33:25 AM
Alan,
Thanks Ken, I have the scissor Jig, I went for 1" because of my Leathermans, they have a 3/4" step which I thought would hit jig. I took the blade out of the last one I did against there recommendation and it was a bloody PITA to get it all back together, it was worth it but i blunted it the next day cutting wire wool so im looking for a faster option....
CopperFish
I bought the scissor jig platform and a variety of aluminum and stainless steel plates in 2"x4" and different thicknesses. Looking forward to making my own!
CopperFish
Finished!! Can't wait to try it out
Herman Trivilino
You will need flat head screws so that the screw heads will not stand proud of the surface of the jig. Also, get some cheap adhesive-backed felt that you can attach to the surface of the platform so that you don't scratch your expensive knives.
There's a YouTube video that you can find by putting my name in the search engine. Since making that video I have made several refinements to the jig.
Now that Tormek has a small knife jig, the only claim to fame for this jig is that it can sharpen long blades, such as a machete. I use it, though, to sharpen all my knives. I set the angle and then I can sharpen many knives at that same angle without having to re-mount the jig or make any adjustments.
