expanded TT-50 thoughts
Started by Ken S, Yesterday at 05:10:58 PM
I have posted before about my preferred TT-50 technique. I learned this by "resharpening" a turning skew. I set the jig according to the booklet recommendations and soon realized that the skew did not fit the standard specs. Instead of just resetting the skew to match the existing specs, I decided to regrind it to the Tormek jig specs. Bad move. It created a lot of time consuming work. The one bright spot was that I became fluent with my TT-50. I should have just shifted the skew gradually, correcting it over several sharpenings.
This experience helped me develop my mental bar graph of using the TT-50. Imagine a bar graph where the horizontal axis represents use time of the tool. The vertical axis represents the cutting efficiency (sharpness) of the tool. The tool begins with 0 time and 100% cutting efficiency. As the tool is used,  the cutting efficiency gradually decreases. Eventually, the TT-50 is used to restore the stone to 100% efficiency. Combining all the points lets us arrive at an average cutting efficiency.
If the TT-50 is used more often, the average cutting efficiency is improved. This principle is shown in the online class on Pressure. Done frequently, only a very light cut is needed, perhaps only half a number on the micro adjust. Wear on the grinding wheel in minisculs. For heavier or prolonged use, efficiency can be improved by leaving the TT-50 preset in a second support bar.
Here is a link to the Pressure online class. There is much good information in it.
https://www.youtube.com/live/7laP_ysnMwo?si=FzjiYp79vs5zLKfS
