Author Topic: diamond tip dresser  (Read 3051 times)
Offline mptvexl
  • Newbie
  • I'm a sharp craftsman!
    • View Profile
diamond tip dresser
« on: June 15, 2022, 07:10:16 pm »
Hi I borrowed a wheel dresser from a friend to true up my wheel.   It's a fairly old basic model that has no screw thread adjustments just an attachment that goes on the bar running across the wheel to which you slide on the square section tube which has the diamond dresser in it.  When he gave it to me he pointed out the the jagged edge of the diamond saying that this is what is cutting.  I've trued my stone but noticed later that the diamond tip was smooth.  I looked on line and all the diamond tips I've looked at are smooth but when he lent it to me it was definitely rough feeling.. Am I just unfortunate and the tip wore out whilst I was using it or is it still good.  Remember it is an old style dresser.  I've added some photos.  Thanks for looking Michael
Offline cbwx34
  • Hero Member
  • QR Code --> Calcapp Knife Sharpening Calculator
    • View Profile
Re: diamond tip dresser
« Reply #1 on: June 15, 2022, 08:51:42 pm »
The diamonds are embedded in that copper colored tip... it's designed to wear away and expose new diamonds.  Look at it under magnification, and you should see some small diamond particles.  You can see some pics in this thread...
https://www.tormek.com/forum/index.php?topic=3647.0
... and some more info in this thread...
https://www.tormek.com/forum/index.php?topic=4259.0
More information on your truing tool...
https://www.tormek.com/media/861601/hb10en_adv50d.pdf
Knife Sharpening Angle Calculators:
Calcapp Calculator-works on any platform (Just point your phone at the QR code)
or, a list of available Calculators
Offline mptvexl
  • Newbie
    • View Profile
« Reply #2 on: June 16, 2022, 10:02:32 am »
Hi Thanks for the reply.  When he gave me the tool he pointed out the diamond which was definitely rough like you could feel the diamond which was like a set of points.  I'm just wondering if this was an old style.  I understand what you are saying as I have seen new ones on line and realise the technology of these.  If you look at the photo of the diamond tip I have given you can see the score marks from the wheel.  Well I can easily file it smooth.  I'm adding another photo so you can compare. M
« Last Edit: June 16, 2022, 10:07:32 am by mptvexl »
Offline cbwx34
  • Hero Member
    • View Profile
« Reply #3 on: June 16, 2022, 01:41:52 pm »
Although the design of the Truing Tool has changed, the copper tip with diamond embedded has not, as far as I can tell.  I have the same model as the one you're showing, as well as a new one, and they look the same to me.  It's designed to wear away and expose new diamond pieces.  The pdf I linked to earlier explains this.
I don't see a reason to file it smooth... it will wear in use.
Offline 3D Anvil
  • Full Member
    • View Profile
« Reply #4 on: June 16, 2022, 05:00:37 pm »
I don't think there's any need to dress the tip, as the stone will wear the metal away.  But if for some reason you wanted to, I think you could put a *teensy* drop of ferric chloride on the tip and let it sit for a few minutes.  Then rinse with a water/baking soda mix to neutralize the acid.  That's how you recondition metallic bonded sharpening stones.  The acid eats away the metal and had no effect on the diamonds.
Offline mptvexl
  • Newbie
    • View Profile
« Reply #5 on: June 16, 2022, 05:22:28 pm »
Hi  Thanks for the replies.  I only filed it to show how soft it was which I did with a old needle file that was to hand.  I would have thought it wouldn't file that easily.  I've looked at the pdf and I definitely don't have diamonds like that on this tip.  I am speculating that the tip does not expose more diamond as it wears down and going by some of the pictures where there the diamond spread is not uniform, like more diamond on one side than the other, suggests to me that the dresser loses it's diamonds eventually with use.  M
Offline cbwx34
  • Hero Member
    • View Profile
« Reply #6 on: June 16, 2022, 05:59:27 pm »
It doesn't take a lot of diamonds to work... I guess the proof is in whether or not it trued the stone.  Here's the tips of the two I have...
... either one will adequately true the stone.
If you're not seeing new diamonds being exposed, I suggest you (or the owner) contact Tormek support and ask them about it.
Offline mptvexl
  • Newbie
    • View Profile
« Reply #7 on: June 16, 2022, 07:04:02 pm »
Yeah I think that's the way to go.  If you look at my photos of the tip you will see nothing there that will compare to all the photos I am seeing.  Thanks M
Offline mptvexl
  • Newbie
    • View Profile
« Reply #8 on: June 22, 2022, 09:20:13 am »
Hi to all those that helped me.  I just thought I would give a FYI about the diamond tip which I got from Tormek support and that is only the first 2.5-3 mm of the  tip has diamond in it and that mine has worn out. M
Offline cbwx34
  • Hero Member
    • View Profile
« Reply #9 on: June 22, 2022, 02:41:22 pm »
Interesting, 'cause at this time in the video Tormek put out yesterday...
https://youtu.be/syUSkWdo5nY?t=1474
... he says you can use it until the tip is "even with the surface" it's mounted in.   ???
Offline mptvexl
  • Newbie
    • View Profile
« Reply #10 on: June 22, 2022, 06:28:07 pm »
Hi Before I ordered a new one I I checked out the tip by sanding it on belt sander, gently mind and no new diamonds appeared. So from an unbiased tester what they told me in the email seems to be right.  Ok Having said all that what I think happens from new is that when you get it the tip is smooth but as soon as you start using it the copper in between the diamond wears away exposing the diamond hence the rough feel but if you look at all the close-up photos you can see the dispersal of the diamond is not uniform so every time you use it the copper holding the diamond can at times wear away and therefore the diamond becomes unstable,  A bit like a wobbly tooth in bad gums and eventually it falls out  As for the video, well lets face it, it's an advert but in my recent experience the tip is mostly copper and will not last to the housing surface.  Ok just to make a point I have just gone down and held the dresser tip to the stone and I'm attaching the photos by increments #1 being the first grind #2 being the second and so forth until I'm within a smidge of the housing at which point I went no further so as to respect my friends loan and to me there are no more diamonds present.  looks like I'm going to have to post the remaining photos in the next post
Offline mptvexl
  • Newbie
    • View Profile
« Reply #11 on: June 22, 2022, 06:30:43 pm »
The last photos
Offline mptvexl
  • Newbie
    • View Profile
« Reply #12 on: June 22, 2022, 06:31:56 pm »
Aint no new diamonds in that thar dresser
Offline cbwx34
  • Hero Member
    • View Profile
« Reply #13 on: June 22, 2022, 07:56:07 pm »
An interesting thread because both that video and the manual indicate (or at least imply) the copper has diamonds throughout.
Quote from: From the manual p.138
The cutting tip consists of diamond grains embedded in a cylinder of copper. The grains are
positioned irregularly like “raisins in a cake”. During use, the soft copper will be worn and the
diamond grains will stick out as peaks on the copper surface. Worn grains will after a period
of time be replaced by new ones. This design gives a long life to the tip.
Certainly different than what you've found!
Offline mptvexl
  • Newbie
    • View Profile
« Reply #14 on: June 22, 2022, 08:06:37 pm »
Reality bites
